Taps leakin a bit of oil when moving...
    Well I uncovered the boat for the first time all winter just to mess around and I had moved the taps Up I think to wakeboard. When I covered the boat back, I was buckling the rear staps looked at the flap and noticed a bit of oil sitting there. Havnt looked into it too much but any ideas as to what it might be
    For Those About To Ride We Solute You
    Mine has started leaking to, got so bad that the the oil was coming out the bung/drain hole on the back of the boat and the taps won't go into slalom position. Have disconnected pump temp from switch as I need to drain the tank out a bit more as I need to move it out of the way to investigate further. My impression is a pipe has either split or come away at one of the fittings, should get the boat in the water this week to use up the petrol so that I can investigate further.
