Originally posted by chpthril
View Post
I needed 2 up front
Taped off the area and marked where to cut/drill. I used the rubrail, mid-cleats, tip of bow, and handrail as reference points to get both cleats in the correct place.
Removed the 2 bow speakers to give me access to the center bow cushion back mounting studs. Removed seat back
Make sure you have room to drill and work on the backside
Drill and cut as needed for your cleat. Double check whole saw size first. Bevel edge of hole to help prevent cracking.
Test fit
Add a bead of 3M 5200, install cleat, tighten, clean excess sealer/adhesive. Reinstall seat back and speakers.
