Originally posted by 3mk
View Post
Mercruiser Part Info
This is a sticky topic.
Originally posted by 3mk View Postdo you think the guys at the shop tow the boat down to the lake to work on it.
Originally posted by petrey10 View Postthats awesome!.... The impeller under the sea water body assembly is the impeller we want to change each spring right??? Do you need any other parts to go along with it?You'll get your chance, smart guy.
Originally posted by Zac93218 View Postthat website was perfect! helped me easily find the starter and fuel filter i needed.
BUT
it did not help me with finding the correct oil filter....can anyone help?
i have a 98 tige pre 2002 wt with the mercury ski comp 5.7 v8 SN# 0L006922
Did a tune up this spring and thought I would share some NAPA part numbers in case someone else needs them. The cap/rotor/coil/wires are marked as Marine and typically have the Mercruiser number in the description or details.
Coil 18-5438
Wires 18-8804-01
Rotor 18-5431
Cap 18-5395
Plugs (from my shop manual): Champion: RS12YC, NGK: BPR6EFS, Or AC-MR43LTS
Belt 25060878
