Mercruiser Part Info
This is a sticky topic.
    I found the Performance Product Technologies"]Performance Product Technologies[/URL] site to be super helpful when trying to figure out what parts were where on my Mercruiser 350 Tournament Ski after my alternator went bad on me. I found wiring diagrams and everything.
    Hope this helps.
    The link is not working correctly.
      Hmmm, not sure what happened there, but it was working.
        Lee-
        I tried this morning and I was able to pull up my engine.
        Sam
        15 Escalade ESV-Black
        08 RZ2-Blue
          Yes, the second link is working not the first link.
            I'm not sure what happened on the first link...it seems to have gotten garbled after I posted it. I'll see if Matt can fix it up.
              Cool! The second link worked fine. Thanks.
                great link dogbert. still looking for starter relay on 02 5.7 mpi.is it like the car on the starter?
                  No. Starters and alternators are specially made for marine applications.
                    ...still looking for starter relay on 02 5.7 mpi....
                    Are you looking for a "starter relay" than controls the high current power from the battery to the starter or a "starter solenoid" which is the little can mounted on the side of a starter that pushes out the drive pinion on the starter driveshaft. A starter relay, commonly used on older Fords, is used to connect high current to a starter when triggered by a remote switch. A starter solenoid combines the function of a relay with the pinion driver mechanism. I don't think either of these parts are "marine", except that better quality materials may be used in their construction. A starter motor designated for "marine" use should not be replaced with a regular car version. The "marine" starters (and alternators) have screens or shields (spark arrestors) over any openings to prevent sparks from escaping into the bilge area.
                    http://www.bluewatermarinesvc.com/html/gm_starter.html
                      my first inboard
                      thanks for the info. the relay I was looking for is on the intake manifold right beside a red 15? amp breaker.this is my first inboard. hooked up water today and started it Idled nice.put in gear at idle speed prop turned but heard a bad noise and I turned it off.the boat has been sitting since last summer. fluid looks and smells good. any ideas of what the bad noise could be?
                        Might have been a dry strut bushing. Put some WD40 on it next time.
                          great idea I like to try the simple things first
                            You really should NOT be putting the boat in gear while out of the water. They water lubricates the bearings inside the strut.
                            Common Sense is not so Common
                              do you think the guys at the shop tow the boat down to the lake to work on it.
