what prop comes on a stock 2008 20v? i'm wanting to get an extra. you know just in case bad things happan
Who knows
Depends on how you use the boat! Do you wake board with a lot of weight, do you barefoot? High Altitude lake? Call ACME, they will help you choose the right oneMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Def. wanna get one. I dinged my prop 45 mins into my first day on the water with the new boat. This was out at Tenkiller back in 05 when the water was 20ft. low. And I was in 45ft. of water at that pt... so even watching your depth, it does happen.
Acme actually suggested a diff. prop than the factory prop. I took their suggestion. The new prop put my top speed at 50 mph and some how I still had as much low end grunt. I only know b/c we had driven around for an hour w/ the dealer when I first picked up the boat.Being a major OU fan and a staunch conservative.... I am perpetually vexed w/ the conundrum of who to hate more. Obama or the Univ. of Saxet.
Guest
Originally posted by chpthril View PostDepends on how you use the boat! Do you wake board with a lot of weight, do you barefoot? High Altitude lake? Call ACME, they will help you choose the right one
www.acmemarine.com, 1-888-661-acmeMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Guest
Originally posted by da.bell View Post$400+The cost is higher than I expected. I was buying stainless for my old I/O at under $300.
Originally posted by 1Lab_trainer View PostLook up Marine products on the net. $399 for ACME 537. Now I need to find a puller for $50-$60Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Guest
