When we hit the sand bar it also bent the prop. The dealer took care of the prop. Then I described the noise to them and they contacted the facyory. They told us the center fin should be slightly out of alignment.
If it's not the front fin causes the center fin to cavitate and vibrate. (thats the way I understood it I could be wrong) but if your rear fin is bent that is definitly a good place to go next. Just tweek it a little and see if the noise changes.
GIZMO
GIZMO
