Could someone please help me out on figuring out how to take the steering cable off the steering rod? I have a 2004 20i and I have got the cable almost all the way out. But the end of the cable has a rod on it that is approximately 2 feet long. With the rod still on there is no way it can come up the hole in the floor. Does anyone know how this rod comes off the cable?
Steering cable change
see if anything in here helps you
http://www.wakeboatworld.com/index.p...d=29&Itemid=35Common Sense is not so Common
FIC, thanks a bunch that was exactly it! Sometimes the brain goes into neutral and is nice to have someone put back in gear. It is kind of interesting though, the tutorial that is floating around says to turn all the way to the right but to make mine shorter I had to go all the way to the left.
Where did you get your cable from? My Tige dealer only sells the 18 footer and I don't want to mess with switching the rack and steering around 180 degrees to make it fit. So I would like to buy the right sized cable if it is still made.
