The TAPS system on my 2000 21i generally only works when the boat is in neutral. A couple of times though, at slow speed, I was able to make it work while in gear. Which is the normal way? It makes sense to me that you should be able to play with it to shape the wake while the boat is moving. Also, the handle on my throttle is excessively loose and I can't find the necessary tool (alan wrench I believe) to tighten it properly. I wonder if these two issues are related? Anybody have any insight?
Does TAPS only work in neutral?
Sounds like a wire has pulled loose from the connector or broken inside the insulation and is making connection while the shifter is in natural and breaking connection when you put it in gear.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
http://www.tigeowners.com/forum/showthread.php?t=3782
There is the link. Hope it helps.I had the right to remain silent, I just didn't have the ability. -Ron White
Hey, whatever works for you Ruune! Not entirely sure how hitting your personal stash is going to help my TAPS problem.
So my understanding from this is that TAPS is supposed to work while in gear or in neutral, at any speed. Am I correct is assuming this?
Thanks everyone else for the advice. With the weather up here this time of year, this fix has just become a winter project.
