If you have a 12v test light, here is an easy way to find a bad plug/wire.
Ground the test light, start engine, now take the tip of the test light and drag it up and down each plug wire, all around the boots at the cap and plugs. If you find a crack in a plug, or a weak spot or cut in a wire, the spark will run to ground through the test light and the engine will skip/miss.
Also a spray bottle of water will help create a path to ground and help locate cracked plugs or bad wires.
