I am new to the whole inboard boat scene. I have found it a little difficult adjusting to not having much control at very low speeds. Does anyone have any suggestions?
FYI-01-21V limited
I also have a question. when I back off my trailer I am not able to get it to back to the left. I know the torque will pull it more to the right but I think I should be able to back to the left a little.
Can any explain why this is?
Also how many turns do you have from left to right from center. I thought I read some where it should be something like 4 turns? Mine is like 1.5 turns to left or or right from center. I can also turn sharper to the right then I can to the left. Could that be some of my trouble and how would I correct that? I just replaced the steering cable. I have the rudder in the center when my steering wheel is the center position.
Thanks again,
Sam
FYI-01-21V limited
Thanks again,
Sam
