I've been trying to trace water that has been appearing around the perimeter of the my 2001 22ir for abou a year now. Turns out it's the pop-up cleats leaking when it rains. This put's moisture in all of the compartments. All of them leak even though they are pushed down. Any suggestions to seal the leaks or am I going to have to find replacement hardware. The moisture builds up in all of the compartments and everything gets wet with the heat of the summer.
