Once in a while, actually 3-4 times my boat has given me trouble starting. It will fire right up, then stall. After it will not fire up for the longest time. Leave it sit for a while and it will fire up and run. But if I try starting it 10 or so times it will only think of firing up then die again. There seems to be no rhyme or reason. However it does appear to be happening once every ten hours. I have 50 hours on it in the last month so it is not like it is getting tons of use or anything like that. Just happened again tonight. It will run fine for a good time now, but I know it will happen again after about ten hours. What does everyone think?
Where is the fuel filter on these things? I know the gas I use is good, but the previous owners I am not sure.
Thanks
Thanks
