I have the standard buddy bearings on my trailer with the rubber covers/bra and I keep losing the covers on my brake axle. I keep the bearings serviced and the grease level is always up. Any suggestions on how keep covers on? Also, thought about converting to oil filled hubs. Any comments or opinions on this?
Losing Bearing Covers
When you slide the covers back on, you need to burp the air out. As the hubs heat up it will pop them off.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostWhen you slide the covers back on, you need to burp the air out. As the hubs heat up it will pop them off.
