How to tighten a handrail?
    Does anyone know how to tighten a handrail in the bow?
    Common Sense is not so Common
    Crawl under the storage areas and grab that wrench. You might have to take the cushion off in able to get to it. Have fun...
      get some longer sums and you will have no problem at all...
        How does the cushion come off?
          The cushios are bolted to the inside of the boat. You have to get behind the cushion with a wrench to get them off. Now, that is how my boat is, your shouldn't be anything different.
            Be glad you don't have a pre model......ughh.
            http://www.wakeboatworld.com
            []) [] []V[] [])
              Got it done... ended up taking out the speaker.. which was the biggest PITA!!!!!! Now im a little itchy but I feel good knowing its tight.
                Fiberglass. That will be itchy for a few days. Just scrub the hell out of the area....
                  hah what area...
                    arms and forehead
                      Your forehead was that close?????? That is why they have handheld mirrors for....
                        no no no i wiped my forehead a couple times
                          Doa write up for wakeboatworld.com
                          The sun never sets on a badass
                            Okay, that sounds better.....
                              you sure you werent trying to fit your head in there?
