The shifter bracket bolts on to a shaft. Trans fluid is leaking around that shaft while the boat in running. I imagine that there is a seal on that shaft inside the velvet drive that has gone bad. Looks like I will need to pull the drive out and replace the seal. Anyone had this problem or know of an easy fix?
Oil leak in my Velvet drive
Originally posted by kimdobbins View Postlooks like its the shifter spool seal, but I cant see any way to get at it without taking the trans apart.
Send a PM to Lee or FIC. They should be able to tell you for sure.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Alright, I give up...........what model/year boat ya gotMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
