OK, paddle wheel appears to be in good cond, spins very freely, and does not appear to be installed at an angle or on a bent shaft etc.
I did the system reset, still no speed reading.
So I called PP last week, did a voltage check on the wires going from the paddle wheel to the module. Red and Bare give me a full 12V, so that's good. Green (speed signal coming back from the wheel) and Bare give me 2.5 or 0 volts. I know I should be getting a 12V or 0V on the green and bare, or avg if I spin the wheel.....so is the transducer bad at this point, or maybe just the paddle wheel is defective???? Anybody ever have this issue?
