Hey guys,
Monday night we were out surfing and we had the crap weighted out of the boat. Water above the rub-rail sorta thing
The tranny seemed to be slipping, but I again ignored it because I figured it was cavitation on takeoff. Then when we took it around the lake to "burn off a little carbon" it slipped on takeoff. I had this issue a little last year, right after I bought it, but that proved to be bad fluid. Changed the fluid and it was fine.
I checked the fluid in the driveway that night and the color was nice and red. Obviously I need to check the level on the lake, so it might be that the level is just a little low.
At one point, the gal driving shut off the bilge pump....not sure why. Anyway, after about an hour, my daughter noticed water running out of the bilge onto the floor when we were pulling someone. Question is, could having too much water in the bilge cause the tranny to slip?? Again, the fluid did not look frothy, and looked like fluid that only had about 15 hours on it....which it does.
We're going out again Friday night, so I'll get out a little early and see if I can replicate it, and check the level. But any experience with bilge water causing the tranny to slip? There appear to be no leaks.
