So I talked to the guy's that rebuilt my Mercruiser 350 MPI today. The official cause of the motor needing a total rebuild was that a valve seat fell out of the head. It fell into the cylinder where it caused much damage to the block and pistons. Has anyone ever heard of this, in a boat engine, or even an automobile engine? I don'tknow enough about these engines and if this is even possible. The guy who sold me the boat seems to think this is impossible. I will try to contact Mercruiser directly, but if anyone has any wisdom on this I would appreciate it. Thanks.
Blown Engine Diagnosis
Yes, usually caused by running the engine hot. The valve seat is press-fit into the cylinder head. If the engine runs hot enough, the head will expand and allow the seat to loosen up and fall out.
It may have happened some time last season out and may have taken a few hours to show it's ugly head. Do you know if the engine showed any signs of cooling system repairs??? impeller, water pump, hoses?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Ok
I am confused.
The valve seat is pressed into the head. (Usually from the top)
The valve is inserted from the bottom. There is a spring that goes over the valve stem. With some sort of retaining clip. So for the valve seat to come out, doesn’t the valve need to come out first?
(the valve head is to big for the seat to go over, and the valve seat should be one piece)
Also I am not questing the repair, just trying to under stand for future refenceTige, it's a way of life!
Originally posted by whitlock87 View PostOk
I am confused.
When a seat drops out, the valve will not fully close. When this happens, the piston will hit the valve face and usually break it off and then it will punch a hole in the top of the piston
I'll try to find an exploded view (pardon the pun)Attached FilesLast edited by chpthril; 06-12-2007, 12:57 PM.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Thanks for the great info CHPTHRIL. You sure do know your motors. I just bought this boat in January, and as far as I know, there were no cooling system repairs done to the boat. The rebuild shop did say that the heads were warped slightly, which seems to fit in with the excessive heat theory. Thanks again!
