They stopped working. I press the switch and the red light on the switch does not light up. Seems it is tripping the breaker. I'll reset the breaker and flip the switch and I still don't get anything but it doesn't trip the breaker right away. I'll check a few minutes later and the breaker appears to be tripped. What can I check? Burned bulb somewhere?
Courtesy Lights
Originally posted by evil0ne View PostThey stopped working. I press the switch and the red light on the switch does not light up. Seems it is tripping the breaker. I'll reset the breaker and flip the switch and I still don't get anything but it doesn't trip the breaker right away. I'll check a few minutes later and the breaker appears to be tripped. What can I check? Burned bulb somewhere?
If this doesn't work, then the short could be between the lights and switch. Unless the breaker is tripping even when the switch is off, then the short is between the breaker and the switch.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by zad0030 View PostHow do you unplug one of those boogers?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by zad0030 View PostLike this?
Sorry EvilMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Originally posted by chpthril View PostUnplug and re-plug each courtesy light one at a time to check for a shorted lamp. When the "bad" one is unplugged, the others should come on and the breaker should stop working.
If this doesn't work, then the short could be between the lights and switch. Unless the breaker is tripping even when the switch is off, then the short is between the breaker and the switch."a what? i can['t] say/spell/pronounce that word..." - wannabewakeboarder
"the plural of boo is booze."
Originally posted by evil0ne View PostI'll be checking this weekend. And if it is shorting with the switch off?Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
Well it looks like I found the problem on accident yesterday. Looks like both lights in the lockers were left on and are now burned up. I put both in the off position and the Courtesy Light switch worked and the LEDs in the boat turned on."a what? i can['t] say/spell/pronounce that word..." - wannabewakeboarder
