Unknown Wire labeled Taps
    Ok so I was hunting around trying to make a courtesy light work and I stumbled upon a wire labeled Taps, not connected to anything. I have not tested it to see if there is any power or anything. Anyone have an idea?
    Its the red one in the center with the yellow cap on the end.
    Common Sense is not so Common
    Does your TAPS work?
    If you ain't falling.. you ain't trying hard enough..
      Yes, There is nothing wrong with the TAPS.
      I think it might have something to do with the fuze.. but I have no clue.
        not sure... who ever had our boat before us rewired it so there are ALOT of wires that make no freaking since. but g.l
        For Those About To Ride We Solute You
          Anyone know what this thing is!!?
            Ok update went out moved some more wires around, The black ground is hooked up to the black ground wire from the taps box. ANYONE KNOW ANYTHING ABOUT THIS!?!
              Lee.. Someone?
                Please..
                  who cares?
                  everything works so dont worry ha
                    But I want to know if we can use this. We wanted to wire the TAPS to turn on and off by one of the ACC switches. And becuase this has the same end that would connect to the switch, I wanted to know what it goes to and what its purpose was.
                      Why don't you hook a multimeter up to it, and see if it is even connected to anything? Check it while adjusting TAPs, key on/off, etc. Take some initiative!
                      http://www.wakeboatworld.com
                      []) [] []V[] [])
                        I was but i didnt know what I was doing so my dad will.
                          I unplugged the black wire taps was non functional if i stick that black wire on a switch will it work with a swich
                            OK, its probably a ground so it probably wont work with the switch? Right?
                            What about the red one?
                            I have a feeling this would have been used for the hydrolic taps system but we have the Lenco and its probably a different setup.
                              Alright we kind of got this figured out now.
                              We want to try and we wire this if we can to a switch. Do you think this will work?
                              1st one is how its setup now, the 2nd is how we are thinking about settting it up.
