I have a 2003 22V. Before I pull the cable out, does anyone know what replacement size. And can I even do it myself? The moment I have dreaded about a V drive has come...... accessing parts I can't reach. Maybe if I pull the cooling intake hoses off, but still not easy. Anyone else done it??????
Should I replace my steering cable myself?
With a Merc it is a bit harder. You will not need to remove or lift the tank. Unbolt cable from the tiller arm, unbolt rack from sterring wheel. Unbolt cable from the tube support. Cut the cable in two by the gas tank and pull both parts of the cable out. Install new cable..... Should need about an 18'.
I already disconnected everything, now I'm trying to get the cable out. I'm going to have to cut it after I figure out how I want to route the new cable back. Putting anything under the tank is rediculous. I shouldn't have to take the boat to the dealer for a mechanically simple process other than the way they chose to route the cables. Poor design.......As well as the lack of drainage from the glove box and bow seats.
Originally posted by c-caron View PostI already disconnected everything, now I'm trying to get the cable out. I'm going to have to cut it after I figure out how I want to route the new cable back. Putting anything under the tank is rediculous. I shouldn't have to take the boat to the dealer for a mechanically simple process other than the way they chose to route the cables. Poor design.......As well as the lack of drainage from the glove box and bow seats.Common Sense is not so Common
With a lot of work and probably luck, I was able to pry up the gas tank and get the cable out in one piece. I measured it and ordered a new one. I plan to route the new cable on top of the gas tank. I'd move my control cables up too, but I don't want to tempt fate. I put the old cable back in the new routing and it should work. I will post a thread when I am done in case anyone is crazy enough to do this after I do. I had to replace the cable on an inline once before and it that was EASY. It should not be this hard. I think it will save a lot of money though.
Originally posted by c-caron View PostWith a lot of work and probably luck, I was able to pry up the gas tank and get the cable out in one piece. I measured it and ordered a new one. I plan to route the new cable on top of the gas tank. I'd move my control cables up too, but I don't want to tempt fate. I put the old cable back in the new routing and it should work. I will post a thread when I am done in case anyone is crazy enough to do this after I do. I had to replace the cable on an inline once before and it that was EASY. It should not be this hard. I think it will save a lot of money though."I want to know God's thoughts, the rest are just details"
