mtnsmith has the correct fix. My dealer fixed mine and said the factory fix is to remove the cooler and put a hose clamp on the tube under the cooler. It won't get pulled out and the caulking is still used to make it water tight.
Can this Cooler drain be fixed?
Originally posted by Paublo View Postmtnsmith has the correct fix. My dealer fixed mine and said the factory fix is to remove the cooler and put a hose clamp on the tube under the cooler. It won't get pulled out and the caulking is still used to make it water tight.
Oh well, at least I was drinking beer when I fixed mine...."I want to know God's thoughts, the rest are just details"
Originally posted by mtnsmith View PostI was also thinking maybe of putting a stainless hoseclamp on the bottom, that way if it does spin, it would atleast stay down though???
One more idea that came to mind on these last posts: go with the different plug type that "flips" instead of "twists". Then a clamp, and etc. might work just as well.Last edited by MRMoffat1; 03-14-2007, 04:59 AM.
