See attachment. This came this way from factory. Dealer "fixed" twice by appying some kind of compound that does not work. Lee or anyone, Any ideas?
Can this Cooler drain be fixed?
Originally posted by MRMoffat1 View PostSee attachment. This came this way from factory. Dealer "fixed" twice by appying some kind of compound that does not work. Lee or anyone, Any ideas?The sun never sets on a badass
Originally posted by TeamAllen View PostI think I used some kind of caulking on mine.
Still holding up great!I don't see how gorilla glue or caulking can work here, but willing to try anything. Anyone else with ideas?
After the dealer tried once, I took the cooler out and used JB on both sides if the drain and has beed solid so far.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
The problem is that the sealant can't resist the twisting pulling when you pull the drain out. What I did was to clean and seal like Lee said. Then I put a dowel rod down the drain, and expanded the copper at the bottom, to hold the tube a little more stationary."I want to know God's thoughts, the rest are just details"
Originally posted by gman View PostYou may want to consider taking the boat back and having it fixed properly. Looks like this may be a product/design issue.
Originally posted by spharis View Post3M FTW!Last edited by MRMoffat1; 03-11-2007, 07:41 PM.
