Ballast Install Pictures
    Great pics Lee, thanks alot.
    What year boat is that, I'm curious about the switch placement in the cluster bezal V's buying the Tige plate/switch setup. How many $'s for the Tige switch set-up anyway.
      I'm gonna make a custom switch plate for all my switches. I don't think I can fit all of mine in the dash
      Originally posted by G-MONEY
        It is a 2006 22v. We also use the factory ballast panel if needed. It is not a low dollar item like the three switch method.
          I'm caught between the Ballast sw's or the amp faders in the dash. I will probably put the faders in the dash and go w/ the factory plate.
            I think I'm going to put my electronic processor on my left side, under the dash area, and then put my switch rack on the right side, just depends, I may see how many switches I can make look good in my dash, or who knows. All options and decisions to make
              Is the dash on 06 "V" like the 05 "V" which i think is very close to the 06 "Ve" if i remember right or is the 06V the same as the 06Ve.
              Thanks again
                Lee
                Thanks for the pictures and the answers. I have the moc up of my manifold and I think it will be tight with the 2 inch tees to make the tsunamis fit. I will know for sure Sunday when I go visit the boat.
                The install you did looks great.
                Is the factory ballast panal on an 05 24V where the perfect pass is? I rememeber in the brochure I think it had the stereo remote up where the guages were and the ballast switches next to the perfect pass?
                Let it be!!!
                  I know that was a question for Lee, but on my '05 22v that is exactly how the set-up is. The four ballast switches are next to the perfect pass control.
                    Lee,
                    where do you get the hard tanks from and do you have any pics of them Thanks
                      Originally posted by xpjim1 View Post
                      Lee
                      That is correct for the 2005's.
                        Originally posted by race fan View Post
                        Lee,
                        We get them from one of our suppliers. I will try to get a picture of them on Friday.
                          Thanks Lee,
                          I have an 06 22v and am seriously considering putting in a ballast system with the hard tanks
                            hard tanks are great, but they just take up so much room. For some of us there just isn't that much room to give but for the others, it sure beats having to patch holes
                              A picture of tanks installed.
                                looks great!
