So I currently have the factory ballast and the front bag empties while riding. After discussing this issue with Andrew over at Tigé he sent me some check valves to install.
My question is I am not exactly sure where to install them. He did note that the valves are installed inline with the bags. I posted some pictures of the check valve itself along with the fill/drain lines and the actual drain pump. Also by the looks of the pictures would I need anymore hardware?
In the first picture the top line is the fill line and the bottom line is the drain line.
Can any ballast people out there help me out?
Thanks,
Matt
Thanks,
Matt
