My spring project is to refinish my wake tower on my 05 22v. The powdercoat has been flaking off in spots for years. I recently removed the tower from the boat and stripped all the powder coat off with a chemical stripper.
Here’s a pic showing one of the flaked areas and the heavy oxidation
After fully stripping the tower, I ran over the whole thing with a sander and 220 grit sandpaper. My expectations were the sanding would remove all the oxidation, but that doesn’t seem to be the case. Some areas look pretty good after one pass but others like below are still heavily oxidized. I sanded this area pretty long and this was the best I could do.
Any ideas on what I can do to get this aluminum cleaned up?
