I have a 2014 RZR. The other day I was going through the boat and after I moved it I noticed some water dripping from my v-drive under the boat. Wondering if this is something I should worry about or is it normal?
Also, when I lifted the floor up to look were the v-drive comes through the bottom of the boat. I noticed that everything is covered in oil I believe? Oil filter is tight and all the fittings are tight as well. I’ve attached pictures of both. DB76622A-B415-4AE8-A56B-7A7E7C558874.jpg 41305146-0E75-4D93-B5DB-46FF8A1B94B7.jpg 50125345-D2BC-4C97-AEA1-C2BBBFADC8D7.jpg 03CFE8FC-EE0C-4E99-8723-ED0D95E9BD9E.jpg
