Alpha Z Tower - LED color changing lights
    Does anyone know where I can buy a replacement LED light that goes on the under side of the Alpha Z tower? The light on the left side works normal and changes colors (white, blue, red, pink) when told to do so by the touch screen. The light on the right side turns on like normal, but will not change colors along with the left side light. The right side just stays white the whole time until you turn them off.
    Not sure if there is an electrical fix for this; I was thinking of just replacing it but i dont know who/where that light can be purchased. Any ideas?
    2012 Tige RZR
    Thanks.
    Matt
    Try Boatoutfitters.com they may have what you need .
    surf till u die.
