350 MPI in 2002 21V. I had a backfire through the throttle body which actually popped a hose loose from the idle control valve housing. After replacing the hose Ive been hearing a very loud sucking sound in the throttle body and it was idling high at times.
I replaced the IACV with an Duralast part and I’m still getting the sucking sound but the idle is back down to normal. If I pinch IACV line line at the throttle body the sound goes away but the motor starts to die.
Any ideas?
Any ideas?
