Got to thinking, those that have/had the issue....using original prop or one with more bite?
Curious if prop has anything to do going into limp mode.
I think of it as a truck with large tires. With larger, heavier tires the torque curve is now out of spec. Curious if the extra weight on stock prop results in similar behavior.
Will a more aggressive prop allow better bite which allows the boat to propel forward as the ECM would expect (speed vs load). With ballast, load is obviously high + stock prop with no bite/cavitation = no speed increase.
