Red light on in dash???????
    2004 Tige 22V
    Took her out yesterday for the first time this summer and the tiny red light in the middle of the dash was on and off throughout the day. I didn't notice if there was a pattern or a certain RPM range but thought I would ask the group if you have experienced this and how did you fix it. The boat just had all new fluids put in this week so it shouldn't be a low level issue although I didn't check any of the fluid levels.
    Thanks
    Cooper
    I used to have a 2003 22v -- if it's the trans pressure light, that's normally on at idle. If the trans isn't in gear, it isn't moving fluid, so the light comes one. Once moving, it should go out.
      ok thanks
      I will pay closer attention next time i'm out.
      Thanks
