I’m Wanting to do a compression check on my engine. Boat shops around here act like they’re too good for little work like this or they say they’re out 3 months. I know it’s simple procedure but I’ve never done one on an inboard.
I would assume I would get the boat to the lake and run it for a while, I do not have a fake lake set up yet. Once ready I’d probably pull up to the dock to do the test... pull all spark plugs and test cylinders, one by one. If cylinder is low squirt some oil in that cylinder. Do I need to shut off fuel pump or unplug it?
