Does anyone know any possible solutions why one of my 12V outlets is not working? This past weekend I plugged in a pump that had loose wiring and it caused it to spark and now it doesnt work. Is there a fuse for this?
12V Outlet not working
On older Tiges, there are two of them, one that controls power from the ignition switch (and it powers the dash instruments) and one that powers the accessories (including 12v outlets).
Is it still the same, Matt?Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Originally posted by NICKYPOO
Aren't those things on a breaker? The one on my dash went out once from a ballast pump and it ended up popping the breaker. I just pushed it back in and viola, power restored.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
Originally posted by gman
On the 05's it is not a glass fuse (little fuse) but rather the two prong fuses used today by the auto industry.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
That little plug caused me heck in the beginning. The plug in my glove box gets the power cut to it when you turn off the starting battery switch. But the one on the dash still works. At first I thought it was broke, before I figured out what was happening.Being a major OU fan and a staunch conservative.... I am perpetually vexed w/ the conundrum of who to hate more. Obama or the Univ. of Saxet.
