Epoxy by itself should be all you need. You might not have covered all of the hole.
Exhaust Leak
Originally posted by lee View PostEpoxy by itself should be all you need. You might not have covered all of the hole.
We are going to apply some more try that and if its not fixed by then we will look into more than just epoxy.Common Sense is not so Common
If the epoxy is not sticking ( staying in place) use a small piece of cloth.
Put some of the mixed epoxy on the tube, then lay down the cloth. Use something to push down the cloth until the epoxy seeps through. ( you might need to add a little to the top of the cloth.)
This is how we fix the fiberglass in our RC planes.Tige, it's a way of life!
