2009 22Ve Rear Compartment Latch
    Got a question about the rear compartment latch on a 2009 22Ve. This is for the walkthrough, or starboard side. I bent the adjustment bolt on the existing latch with a ballast overfill. I was hoping to replace the broken slam latch with a twist latch (what is currently on the port side), which appears significantly more robust. This would transition the latch from a 1/4" or so bolt to a 5/16" or so bolt. I just glanced at it today and I didn't see an immediate reason that this wouldn't work. If that is indeed the case, does anyone know the replacement part? I believe that it is a 2.5" hole and that this part would suffice.
    https://www.boatoutfitters.com/large...rine-cam-latch
    Thanks for any suggestions and advice!
