I'm getting ready to ...sniff... ....winterize my 2150wt. This is the first year I've had this particular boat, so I looked specifically at changing the oil. what I found confuses me a little. It looks like the oil drain plug is on the very bottom of the oil pan, (not at the edge of the bottom to provide easy access) This configuration only leaves about 1", maybe 1 1/2" between the oil pan and the hull. How are you supposed to drain the oil without spilling oil all over the bilge? anyone done this before? I can think of some work arounds, but would rather not go to those lengths just to change the oil.
I am eager to hear your thoughts!!
Thanks
Thanks
