So I have a little question on the 2016 touch screens. I can't seem to get the touchscreen to turn on or stay on when using the battery in the on position. It turns on just fine when set to combine or by starting the motor. talked do dealer he thought bad battery but they both say 13volts. so I donno.
tige touch not coming on
Sounds like your cranking battery is shot and deep cycle is doing all the work. Next time you go to the slip take a multimeter and test cranking battery voltage before startup with switch in off position. Cranking batt will probably be the inboard battery. I will bet its 11.8 or lower. Another quick one would be try to crank boat in just on position. If it is suoer slow cranking or won't crank at all that battery is shot.
Im guessing here but that 13v is while running which is your alternator doing it's job. Engine off key on will probably net a different reading at touch screen.Last edited by freeheel4life; 04-26-2018, 06:15 AM.
Also agree voltage problem. I had a similar issue on my 14 Z1 on our first outing last year. Idled around the marina for a while to let the battery charge from the alternator and put it on a tender when we got off the water.
Make sure that you are reading the voltage with a meter at the batteries in either the "off" position or "on", sounds like you may have the battery switch in combine and reading the voltage through Tige Touch.
Originally posted by bsreid View PostStarting the boat with the battery switch in on works just fine, not sluggish at all. When you think if it that makes sense as it would be the accessory battery. Dealer said they’re deep cycle batteries so you can’t test them with a volt meter.
I don't know how to say this politely, but your dealer is wrong. It's literally as easy as taking a multimeter and poking a lead to ground post and a lead to pos post. Read voltage. There's some mich nicer testers that will also measure CCA potential which helps give clues to a batteries health.
If you key on but engine off with screen on it should show you house batt voltage and a cranking batt voltage at screen as well.
This is confusing.
Leave the combine switch OFF.
Does the screen come on? Sounds like no.
Does the engine come on? Sounds like yes.
If so, after the engine comes on does the screen then come on? Sounds like yes
If that is the case, sounds like one battery is toast and when the engine is running the alternator is active and running the radio in spite of the bad battery.
Koolaid, is that what would happen with the alternator?
So both batteries are above 12v with a volt meter.
With engine off switch from combine to on and all power is lost on gauges and dash. Turn engine on and screen pops up on both settings.
Oh and when we turn the key with the battery on it gets power the gauges try to come in and then go off.Last edited by bsreid; 04-30-2018, 02:17 AM.
Originally posted by bsreid View PostSo both batteries are above 12v with a volt meter.
Oh and when we turn the key with the battery on it gets power the gauges try to come in and then go off.Oh Yeah!
