Boat is 2003 22V 5.7 merc with 250 hours.
Last season the engine would cut off sometimes when under a load and higher RPMs. So like surfing or high speed cruising. There was no sputter or stumble first, the engine just straight turned off. Every time it did it there was always a strong gas smell. The boat would always immediately start right up again and act normal. This only happens maybe once an outing. I'm gonna throw some parts at it this spring and see if I can fix it. I plan on ordering new plugs, wires, distributor and cleaning the flame arrestor. Any other suggestions? Maybe check fuel pressure too?
Thanks!
Thanks!
