After three years of letting Tigé do it (I figured it would help with warranty) I decided to tackle this myself on my 2013 Tigé Z1. It has the PCM EX343 with 1.48 Power Plus. I had a couple concerns to run past you guys.
First issue was thhis nut on the vdrive. It was completely loose and spinning. I assume it is meant to be torqued. What is it and what should it be torqued to?
Next issue came when I was attempting to drain the oil. This hose is supposed to run out through the bilge drain. However it doesn't fit! Am I missing something? I think it would be easier to get a pump.
I took videos to try and out together a how to. I must say it was harder than I expected. There are 7 plugs, 3 hoses plus the 4 ballasts. You need about 5 wrenches plus a socket to do all the hose clamps. I used 30L of antifreeze too. Btw I couldn't find any marine grade stuff. I asked at the dealer and looked at 5 stores. Everyone just uses standard -50 RV antifreeze, so that's what I did too.
I'll have to do the oil and impeller in the spring.
