No rev 3 brackets. Just forgot to take a pic before I left the boat and used this one. I would like to do the rev 3, but afraid I'd F it up and with not having a backup for replacements could be sol.
Mines came loose so many times this year. Red loctite it in and your good to go.
Yeah, I'm missing both of them, ugh. I believe it's the same bolt threads used to bolt the VX brackets to the platform brackets. I just need confirmation along with the thread length and shoulder length.
Thanks for the suggestion on the loctite, I'll do the same once I figure out which socket cap screw it is.
Agreed. I am so happy with my wave right now I'm not sure Rev 3 would be an upgrade. The suck gate changed everything.
I have three more of those bolts, but they are in my boat off-site. I'll do my best to track them down and send measurements. All I did was go to the dealer and they knew exactly what I was talking about. Is that not an option for you? As a side note, I would use blue loctite, not red. If you ever want to remove that platform again, stick with the blue.
I know I'm not alone in this, but my platform bounces up and down all the time no matter how tight those bolts are. It seems that the brackets on the transom have worn down and have play in them. Anyone else dealing with that?
