I just bought a fake-a-lake and was wondering how long it should take before seeing any water come out of the exhaust? I tried using it once already and never saw any water exit the exhaust. I know I had what sounded like a belt squealing but I'm not sure if it could be that or a what a bad pulley would sound like. Any help would be appreciated
Looking for alittle help
hull vent.jpghull vent.jpgOriginally posted by Spicer View PostI just bought a fake-a-lake and was wondering how long it should take before seeing any water come out of the exhaust? I tried using it once already and never saw any water exit the exhaust. I know I had what sounded like a belt squealing but I'm not sure if it could be that or a what a bad pulley would sound like. Any help would be appreciatedLast edited by mikemcclain8; 08-18-2017, 01:00 PM.
Sounds like you need an impeller now. Did you put the F-a-L to the correct intake? Sometimes you need to put the trans in neutral and bring the engine rpm up to like 1200 for a few seconds.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
If you've got a Merc engine, im betting the impeller has flipped the wrong way, resulting in the squealing noise and not water from the exhaust. If it has the composite housing and never had the impeller housing changed or you dont know, get the whole housing assembly not just change impellerMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
after the engine was running how much water was still getting out of the F-a-L? As stated above, were not trying to insult your knowledge just trying to diagnose. Fake Lakes are a royal pain to get positioned just right so you don't starve them for water and eventually burn through an impeller in 30 seconds.My life's journey is not ending up looking pretty, its sliding in broadside, used up, worn out, screaming "What a Ride"
Originally posted by chpthril View PostIf you've got a Merc engine, im betting the impeller has flipped the wrong way, resulting in the squealing noise and not water from the exhaust. If it has the composite housing and never had the impeller housing changed or you dont know, get the whole housing assembly not just change impeller
Originally posted by Thegerman618 View Postafter the engine was running how much water was still getting out of the F-a-L? As stated above, were not trying to insult your knowledge just trying to diagnose. Fake Lakes are a royal pain to get positioned just right so you don't starve them for water and eventually burn through an impeller in 30 seconds.
Those composite Merc housing are known to get out of round over time of if the impeller runs dry and gets hot. This leads to repeated impeller failure over short periods or priming issues.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
