I have no doubt that engine rpm plays a factor in operation of speed set, but ill stand by my statement that its set and holding point is MPH based. Its not like perfect pass that had an RPM mode ideal for running a course and mph mode for boarding,
As to the nauticlogic, does it not take the place of the paddle wheel and supply the GPS based speed input?
Unlike old PP, speed set is not a stand alone system. The speed set touch pad is an appendage of the ECM. You are simply telling the throttle position motor to hold based on the speed set input, not the manual throttle lever mounted PPS. You cna command the speed up or down electronically in increment, rather than trying to do it manually via the throttle lever.
Unless the fuel is old, I would not run it out and replace. I would certainly not replace with a higher than recommended octane unless thats all thats available. There is no performance benefit to running an octane higher than required. They contains the same BTU p/oz, so same power once ignited. However, the higher octane takes more heat (resists high/has higher flash point) than lower octane. But again, no performance benefit. IIRC, the marine power 340 5.7L requires 87. Its always safe, in regards to pre-ignition, to run a higher oct, but no performance benefit that offsets the added expense. With or without ethanol is an entirely different topic and not related to octane.
is that #knowledgebomb enough for you elevated?
