have 2004 switch, 13x12 3 blade prop on there now. would a 13x13 4 blade work as a backup
prop
Switch is a DD, correct? If so, stick with a 3 blade.
Many upgrade the prop, then retain the existing as the back up. But this depends on how the boat is used, as to which prop to go with.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
ok, so you wont be looking for a low end/hole shot stump puller. Is your current prop a nibral CNC or an older stainless? Of the ACME props, a 13 x 12 would be a 515. Thats a middle of the road all around prop that can wake board, slalom or barefoot.Mikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
