I have a 2007 RZ2. I've had this problem all season. I've had several mechanics look at, been on the phone with Tige and marine power and nobody knows what the problem is. When ever I put down the throttle I lose power. Engine is on all the lights are on but just no power to the throttle. This happens every time I take the boat out whether cruising pulling a wakeboarder or surfing. It's intermittent but happens at least 2-3 times each time I take the boat out. I have to put the boat in neutral and then start again. I've replaces the throttle protentimeter, checked all lines, pressure and fuel pumps. It doesn't seem mechanical. Marine power wants me to send in my ecm to them to reflash or fix. Anyone else have this problem or know how to fix it? If I send my ecm to marine power from Cananda I'm worried I'll lose weeks of my season. Anyone know if I can get a spare ecm that would work with my boat while it's being looked at? Any ideas or suggestions are appreciated.
Losing power to throttle
i would check the reo-stat on the back of the shift linkage those were a definite problem of what your explaining , I would also try running all on one battery and get some bolt readings and then try it again on the other battery again.
I'm willing to bet it's the reo stat if I had to guesssurf till u die.
I too own a 2007 RZ2 and am having the same problem. After towing for about a half hour yesterday, my throttle started sputtering when trying to take off but would be fine when I got up to speed. Also I noticed when I'm at idle speed the RPM's become very erratic and I begin to lose power to my throttle control. Any advice is appreciated
Paddle wheel
Originally posted by Nruane93 View PostI too own a 2007 RZ2 and am having the same problem. After towing for about a half hour yesterday, my throttle started sputtering when trying to take off but would be fine when I got up to speed. Also I noticed when I'm at idle speed the RPM's become very erratic and I begin to lose power to my throttle control. Any advice is appreciated
