Speedometer not registering. Where do I start to look?
2011 RZ4 speedo
Neither the analog needle or digital display? Start with stuck or broken paddle wheelMikes Liquid Audio: Knowledge Experience Customer Service you can trust-KICKER WetSounds ACME props FlyHigh Custom Ballast Clarion LiquidLumens LEDs Roswell Wave Deflector And More
I'm with Mike. My money is on a bad paddle wheel. If you trailer it a long distance, the wind blowing across it can melt it while its spinning on the shaft. Get under the boat and check that first. It should not be wobbly and it should freely spin.
If its good, lets verify its not something else before you trow down the cash for a new triducer.
Can you see depth and water temp? If so the power and ground is good. I assume you can see RPM when the engine is running. That verifies CAN is good from the powerplant to the dash.
The green wire is speed. Verify you have continuity from the plug at the paddle wheel to pin #5 on the 20 pin engine connector. If all of that is good, buy a new paddle wheel.Oh Yeah!
