I took the boat out for the 2nd time this season and had a about 12 people in the boat cruising at about 18 MPH with everything running just fine and then all of a sudden the boat started marking a load vibration sound? With music playing and all the people in the boat it's hard to say if we hit anything or not but there wasn't any real obvious sound but it was a very sudden change from no vibration to a lot. Afterwords I could run at about 10 mph and the boat sounded fine but if I went up to anything above 12 or 13mph it starts making a loud vibration sound. The boat also feels like it's vibrating a little but the noise is worse. I put the boat up on the lift and expected to see a big dent or something in the prop but everything looked fine. Not sure if a whole blade could get knocked out of angle without really showing a dent and would be more difficult to see? The drive shaft also looked fine, I couldn't see any visible damage.
So I'm trying to figure out if there is something else that could cause this type of vibration to suddenly occur other then the prop? The second thing I'm trying to determine is with a 3 plus week wait at the local marina am I better off just buying a new prop and putting it on to either solve the issue or eliminate the prop as a problem?
My boat is a 2010 RZ2 and I just had it serviced and had the fresh air exhaust installed (I don't think the FAE caused any of the problems).
Any help or suggestions are appreciated, Thanks!
