well..im looking at purchasing a used 2006 20v..it only has 20 hours on it..anyways..i live on the ocean...and it would have to be in the saltwater..all day..and all night..on a dock...i dont think i can get a lift for my dock either...but i was wondering..can i do this..will it still run after 3 days in hte water?....thanks!
20V
we have sold boats that get used in salt water. one i know for a fact sits in the water 24/7 he has had it for 6-8 months and has had no prolblems with any of the running gear.granted it is a harsh enviroment for the boat anyboat for that matter but they hold up well. you could look into adding some zincs if you wanted it would not hurt. and always flush the motor after every use. also spray hardware with a corrosion fighter. also i suggest setting the taps to wakeboard mode when you shut it off this will pull the ram in so no barnicles will grow on the shaft and then end up cutting a seal in the ram. im not sure if yours will default back to slalom ill have to check but if it does it can be wired not to default.hope this helps let me know if you have any more ? . kkoLast edited by kko; 08-20-2006, 02:28 PM.
I am one of those customers that KKO mentioned using their Tige in saltwater almost exclusively. Have a Perko Flush Pro installed and also make sure there is a strainer installed. An alternative to a lift is a Jet Dock. Some friends of my parents have one for their Nautique and they love it. They are not allowed to have a lift where they live so this was the solution they found. Also make sure the boat has the stainless gas struts and hinges and whatnot. The zincs KKO was speaking of are scrificial anodes. They dissolve easier than the other metals so they essentially take the attack away from the expensive metals. There is a current alway running through the boat and to the water which is what dissolves the metal. Here is a good link to explain it all. Let me know if you have any other questions, I have been a saltwater boater my entire life, KKO is also a great resource for Saltwater boating questions.
http://www.blue-crab.org/zinc_anode.htm
Jet docks-
http://www.jetdock.com/pages/boat_lifts.asp
Perko Flush Pro-
http://www.skidim.com/products.asp?dept=1046
Sea Strainer-
http://www.skidim.com/searchprods.asp
you will most likely have to add a flush unit. you can have a factory one but its not that common.perko is what we use they go inline and you hook a garden hose to it. it has a spring loaded valve that makes the water flow only toward engine (make sure u install it the right way) you can get them from just about any marine parts house. check with your dealer. and i would also recomend the sea strainer its a must have IMO. no boat leaves our shop without one.
Both the Flush Pro and the Sea Strainer are quite easy to install. They both just go inline with the water supply from the pick-up. The strainer comes with a bracket that you would have to mount on the seat back above the transmission and the flush pro just goes between the water intake and the sea strainer, I could take a picture of my set-up if/when you want to install these items yourself. They are not very difficult and worst case you would have to buy a new length of hose to supply water from the pick-up.
By the way, what part of the country will this boat be sitting. I am down in Florida and our water grows stuff on boats in about a week. My parents are in Maryland and they only get about a dozen barnacle a month on a 42' catamaran.
