I just bought a 2002. The previous owner said a friend fell on the window and broke it and the frame was bent so he took it off and couldn't find it. I would prefer to replace it, but have scoured the interweb with no success. First, does anyone know where I can get the window frame? I think if I get a frame I can come up with some glass or just use plexi. Thank you.
2002 Windshield and Frame
Mine is a 99, and the windshield is a "Water Bonnet" which was bought by Taylor Made Systems, www.taylormarine.com. On the base of your window frame you should be able to find a part number and then order from Taylor Made. They started to put the part numbers on the frames in 2000. If you can't find the part number call the parts dept at Tige' with your Hull ID number and they can give you the part number. Taylor Made can then tell you if they still offer your windshield or parts. They still makes the glass and parts for my 99, but there is an 8 week lead time.
