Originally posted by anhaney
View Post
replacing bunks
anhaney
Originally posted by dogbert View PostAny time. That goes for any one else who wants to come drive my boat so I can surf, too! I gotta work on that 2 person weighting a bit more...just couldn't quite get the shape to work.It was still fun and the water temp contrary to everything I have been told was great. I had a blast and appreciate it. The wings were great too.
Can I ask a dumb question, did you replace the treated wood parts? My 2x4's don't look bad, just a part of the bunk carpet is bad at the very end when the boat is loaded. Do I need to remove the old carpet that is on there or can I just rap it w/ new carpet overtop and slide it under the hardward plate to hold it on? I notice that I am getting a couple of scratches on the bottom of the boat from this and would like to jump on it now before it gets worse. I am putting the boat in the water this wkend and I plan on inspecting it to see what I need for sure. The bunk carpet would be around $80 for all 4 bunks. I am looking at the 12" wide stuff for a regular 2x4, does this sound correct also?
Has anyone ever use these or know anything about these? I figured I would need about $90 worth, I would need 3 sets.
http://www.overtons.com/modperl/prod...=31336&aID=26J
Thanks
DaleDale
2000 21i Tige
Yes, I had to replace my boards because they were starting to rot underneath the bunk carpet. Once you have your carpet off, take a look. Might want to inspect the lag bolts holding on the bunks as well.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
ThanksDale
2000 21i Tige
anhaney
$80.00 no way
[QUOTE=TRD;95903]Can I ask a dumb question, did you replace the treated wood parts? My 2x4's don't look bad, just a part of the bunk carpet is bad at the very end when the boat is loaded. Do I need to remove the old carpet that is on there or can I just rap it w/ new carpet overtop and slide it under the hardward plate to hold it on? I notice that I am getting a couple of scratches on the bottom of the boat from this and would like to jump on it now before it gets worse. I am putting the boat in the water this wkend and I plan on inspecting it to see what I need for sure. The bunk carpet would be around $80 for all 4 bunks. I am looking at the 12" wide stuff for a regular 2x4, does this sound correct also?
$80.00 for for Bunk carpet? Go to Home Depot or Lowe's. Buy carpet that is indoor out door runner carpet. It has a rubber backing on it. That stuff works great and it hold up better than the actual bunk carpet that the marine shops sell.
ThanksDale
2000 21i Tige
Originally posted by dogbert View PostIt depends on the trailer and what they used to construct it.
Mine are getting due and it's 6 yrs old. I am probably average with use and treatment of the trailer, the person I bought it from used the trailer 2x a year--coming and going to thier vacation house on the lake.
Does Trex make 2x4s and 2x6s?? I'm gonna look into that. I bet they'd last ALOT longer than regular wood.Other than that, Mrs. Lincoln, how was the play?
Would Trex 2x4's be as durable and strong? I know when you build a deck, the foundation is normally wood.
Also, my boat is 4 years old, but it only had 70 hours on it when I bought it this year. It now has 90ish. I would think you'd get more then that out of the bunks, but maybe not. Maybe it's the way my wife puts the boat on the trailer.
Originally posted by Waterski-Rebel View PostMaybe it's the way my wife puts the boat on the trailer.
I used treated pine the last time I replaced mine.Cursed by a fortune cookie: "Your principles mean more to you than any money or success."
I know the couple trailer manufacturers here in the Tampa Bay area that I have talked to about getting an aluminum trailer for my tige have all been using cypress bunks. I am not sure how you would get cypress bunks, but they would probably last a long time, the cypress trees do grow in swamps.
I rebuild trailors on the side and have seen some pretty crazy manufacturing.Why on earth a company would screw a trailor together with untreated wood and steel screws I don't know other than maybe wanting to sell you another trailor in eight years.Another problem I found is the butting of two pieces of naked metal without a rust control agent.This is the problem most have with the new trailors rusting from the seems.NC//OKC\\
