Recommendations for sea strainer
    So with all the rain in Texas, there is a lot of debris in the water. On Sunday I had to limb back to the ramp because the pickup and trans cooler were almost completely clogged. Luckily the engine was still getting water but could not go much past idle.
    Does anyone have a recommendation on what to get?
    I've been on the Texas rivers for nearly ten years, and this is what I have used.
    Sherwood raw water strainer 1.25" connection
    Use it in line with a Perko flush valve. No issues to date.
      http://www.indmar.com/Genuine_Indmar...ainer_Pro.aspx
        Here is my thread on the indmar. I would also do a search on this forum for the diy versions. Some guys have made some nice systems
        New sea strainer/flush kit from Indmar
        https://r.tapatalk.com/shareLink?url...9&share_type=t
          Thanks for the recommendations.
          @Captainkurk72 - I have read through your thread with the Indmar strainer a while back. Where you able to change the orientation to allow for easier cleanup?
          I would not imagine there would be a problem if I moved the hoses around. The pickup is on the starboard underneath the exhaust manifold and the trans cooler is on the port under the other manifold. May move it up from near the ski pole.
            h20-ski - I won't be back to the boat till this friday night. I will take a look and make the change if I can. either way I will update my findings.
